  4. New User
Render and Lighting Errors
  4. New User
Bruce
Bruce
Thu Feb 03, 2005 12:01 am
#1 by Bruce
I just received Intellicad PE+ ver 5.1 and am getting the following errors:
Error loading Lighting Dialog; contact technical support for assistance.
Error loading Render Settings Dialog; contact technical support for assistance.
Any help would be much appreciated.
Thank you.
Bruce
  • Thu Feb 03, 2005 7:22 pm
Return to “New User”
  • It is currently Sun Oct 11, 2026 5:01 pm
