  4. New User
polar and tracking options
  4. New User
gallo
gallo
Mon Nov 01, 2004 11:01 pm
Coast City - Uruguay
#1 by gallo
Is there a way to use the polar and tracking as in AUTOCAD?????????
  • Tue Nov 02, 2004 12:40 pm
john gaunt
john gaunt
Tue Jun 01, 2004 11:01 pm
Perth, Western Australia
#2 by john gaunt
It works in Bricscad's ver-4 and has worked in some previous versions. In Icad98 it worked with Dragmode off. It might work in Ver-5.
  • Tue Nov 02, 2004 2:27 pm
Return to “New User”
  • It is currently Sun Oct 11, 2026 3:57 am
