  4. New User
purge
  4. New User
Draftingallday
Draftingallday
Mon Aug 13, 2001 11:01 pm
purge
#1 by Draftingallday
Does Intellicad have a purge command like Autocad has ? I haven't been able to find one if they do.
thanks
  • Wed Oct 10, 2001 8:17 pm
Alosius
Alosius
Thu Sep 27, 2001 11:01 pm
Sevilla, España
#2 by Alosius
Draftingallday,
It has.
Just type purge on the command bar.
  • Thu Oct 11, 2001 3:10 am
Alosius
Alosius
Sevilla, España
#3 by Alosius
Draftingallday,
It has.
  • Thu Oct 11, 2001 3:11 am
MROCK
MROCK
Mon Oct 09, 2000 11:01 pm
Rio de Janeiro, RJ, Brazil
#4 by MROCK
If you prefer the menu, go to Tools/Intellicad Explorer, there you will find the Purge command
Michael Röck
  • Tue Oct 16, 2001 10:15 am
Return to “New User”
  • It is currently Sun Oct 11, 2026 10:30 am
