  4. New User
ole error
  4. New User
phrostie
phrostie
Sun Mar 18, 2001 11:01 pm
guyton ga, usa
ole error
#1 by phrostie
I've been running the free cadopia version with very good results. i wanted to try intellicadms's, but so far i have not gotten past the install.
i'm getting an "ole fehluer" error. any suggestions as to what dll i need to replace/update?
thanks
  • Mon Mar 19, 2001 9:06 am
Return to “New User”
  • It is currently Sun Oct 11, 2026 8:27 pm
