  4. VBA, . NET & IRX
add new menu in intellicad
  4. VBA, . NET & IRX
newbie
newbie
Mon Apr 17, 2006 11:01 pm
Pasig,Manila, Philippines
#1 by newbie
i would like to add a menu and a submenu to intellicad's when the drawing opens. but unlike autocad's vba, intellicad doesn't have a menu class. how can I programatically add a new menu?
thanks in advance
  • Tue Apr 18, 2006 7:55 pm
Return to “VBA, . NET & IRX”
  • It is currently Sun Oct 11, 2026 9:03 am
