  4. VBA, . NET & IRX
Intellicad GROUPs
  4. VBA, . NET & IRX
newbie
newbie
Mon Apr 17, 2006 11:01 pm
Pasig,Manila, Philippines
Intellicad GROUPs
#1 by newbie
I am trying out Intellicad's GROUPS and GROUP objects in VBA, but I keep getting an error message that says that the object doesn't support the operation. Is there a way I can work around this problem?
  • Tue Apr 18, 2006 7:35 pm
Return to “VBA, . NET & IRX”
  • It is currently Sun Oct 11, 2026 12:38 pm
