  4. VBA, . NET & IRX
double click to text - edit like autocad?
  4. VBA, . NET & IRX
ferol
ferol
Tue Jan 20, 2004 12:01 am
#1 by ferol
is possible use bouble click in Icad like in Autocad? because double click now open properties dialog....and this is too slow for editing text...
[This message has been edited by ferol (edited 03-09-2006).]
  • Thu Mar 09, 2006 3:19 am
Return to “VBA, . NET & IRX”
  • It is currently Sun Oct 11, 2026 12:06 pm
