  4. VBA, . NET & IRX
ColumnHeads
  4. VBA, . NET & IRX
shelbyt96@hotmail.com
Sat Nov 12, 2005 12:01 am
Knoxville, TN, 37921
ColumnHeads
#1 by shelbyt96@hotmail.com
Does anyone know how to name column heads in VBA?:confused:
  • Sat Nov 12, 2005 1:36 pm
Return to “VBA, . NET & IRX”
  • It is currently Sun Oct 11, 2026 3:02 pm
