Type Mismatch in Getpoint
I am trying to use the following instruction in VBA ;-
Set P1 = intellicad.activedocument.utility.getpoint("Select Centre Start Point")
This generates a type mismatch error as the function appears to want a start point in the parameters to draw a trace line from. I dont want a trace line and the online help shows examples of getpoint being used without a point being specified.
ENSIGN,
Set P1 = intellicad.activedocument.utility.getpoint(,"Select Centre Start Point")
You need a comma prior to "Select Centre.......
The Point is an optional variable that when supplied provides a trace line and if no Point is provided then no trace. You must separate each variable with a comma.
