  4. VBA, . NET & IRX
AddPolyfaceMesh method.
  4. VBA, . NET & IRX
andreadiloreto
andreadiloreto
Tue Feb 04, 2003 12:01 am
Rome - Italy
#1 by andreadiloreto
The example in the Help guide doesn't run, and I don'tunderstand how can I set the ListOfFaceIndices property.
Thank you in advance.
  • Tue Feb 04, 2003 11:14 am
#2 by John Finlay
See other reply
  • Tue Feb 04, 2003 10:14 pm
Return to “VBA, . NET & IRX”
  • It is currently Sun Oct 11, 2026 9:03 am
