  4. AutoLisp/SDS
Calling VB app from Lisp
  4. AutoLisp/SDS
Remyga
Remyga
Mon Apr 12, 2004 11:01 pm
Kaunas, Lithuania
#1 by Remyga
Hi all,
How to call VB routine from LISP in IntelliCAD? For example in AutoCAd lisp I use:
(setq Test (vlax-create-object "DllName.clsClass"))
(setq answer(vlax-invoke-method Test 'SomeMethod))What alternatives are in IntelliCAD?
Thank for all sugestions.
Remyga, Lithuania
  • Mon Apr 12, 2004 11:19 pm
Return to “AutoLisp/SDS”
  • It is currently Sun Oct 11, 2026 12:00 pm
