  4. AutoLisp/SDS
Lsp routines
  4. AutoLisp/SDS
Draftingallday
Draftingallday
Mon Aug 13, 2001 11:01 pm
Lsp routines
#1 by Draftingallday
What are some of the best places to get lsp routuines ? Do yall use some that I can't find anymore ? I would like to know. Also I would like to learn how to do lsp. Do you recommend any books that I can learn from ?
  • Mon Nov 19, 2001 9:07 pm
mjsmyth
mjsmyth
#2 by mjsmyth
Take a look at www.cadalog.com
Michael John Smyth
Irish / UK Representative
Efnet Autodesk Users Group
www.eaug.org
  • Tue Nov 20, 2001 12:28 pm
Return to “AutoLisp/SDS”
  • It is currently Sun Oct 11, 2026 1:59 am
