Boundary and Region Commands
jeffmorris
jeffmorris
Mon Sep 26, 2005 11:01 pm
#1 by jeffmorris
I have IntelliCAD 6.2 PE+. If I draw some lines that form a closed shape such as four lines for a box and try to use the Boundary command, nothing happens when I click inside the box after clicking on "Select Area >" button and the "OK" button is grayed out. The Region command works. Any suggestions?
  • Mon Oct 02, 2006 4:29 pm
  • It is currently Sun Oct 11, 2026 1:58 am
