Demo 6.2 will not install
Posted: Tue Sep 19, 2006 8:39 am
by Karlheinz
I like to try the demo 6.2 to see if a few bugs are remove (for example, a few line styles will not be printed correct to a PDF).
Unfortunately the demo could not be installed on my WinXp machine with 1GB main memory.
(access violation at address 7c93ae22 in module 'ntdll.dll') …...
Any Ideas?
Thanks in advance
Karlheinz
Posted: Sat Sep 23, 2006 2:50 am
by John Finlay
Karlheinz,
This could be some sort of access to an NT dynamic link library.
Check you have administrator access to your operating system.
Posted: Mon Sep 25, 2006 9:59 am
by Karlheinz
Thanks for your answer, John.
I still have admin rights on my computer, but it wont work - anyway, I have upgraded now my 6.1PE to 6.2PE and I was able to install the 6.2PE. Unfortunately, the trim command still works "strange", it cuts, depending on the direction of the polyline, the wrong part of the polyline, if the direction of the polyline did not fit. So I need several time some LISP routines, which reverse a polyline.....
Also the Script command was not able to run on long script to draw a polyline with approx. 600 points…. (similar in 6.1 and 6.2, so we have here no improvement)
best regards from Germany
Karlheinz
Posted: Mon Sep 25, 2006 7:39 pm
by CW
If you want to reverse a single polyline, PEDIT will do it. No need for LISP unless doing multiple lines at the same time.
