please help me..
1. i attached a drawing file created from autocad2004. it takes a lot of time opening it using intellicad.
2. whenever i want to plot and tried to window a drawing or a paper, the second snapping does not appear. what can i do so that i can pick the second or the other point of the paper accurately?
3. there were many times also that i made mistake while drafting and had to UNDO my commands, and a prompt will appear: THERE IS NOTHING TO UNDO. i have no choice but to repeat my drawing again from the last time i saved it. is there any solution for this.
4. what are the factors that causes a file with corrupt entities? i'm confused by this issue. while i was drawing, the program will just close because according to it, the file has corrupt entities while i'm aware to the fact that i created the drawing from scratch and definitely does not contain a virus. what can i do to avoid these circumstances in the future drawings.
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by asia:
<B>1. i attached a drawing file created from autocad2004. it takes a lot of time opening it using intellicad.
4. what are the factors that causes a file with corrupt entities? i'm confused by this issue. while i was drawing, the program will just close because according to it, the file has corrupt entities while i'm aware to the fact that i created the drawing from scratch and definitely does not contain a virus. what can i do to avoid these circumstances in the future drawings.</B><HR></BLOCKQUOTE>
Seem that there is a bug. I use the latest version, but the error is the same. The undo command not work fine, and sometime, the snap and select not work.
Intellicad can read a drawing from another cad program and convert the foreign file format on the fly before placing the drawing onto your monitor. Sometimes this conversion process loads your computer's brain with calculations and makes it seem slow.
This conversion occurs only in memory and is not yet recorded onto your hard drive in Intellicad's native format.
It is good practice to save all drawings (including attachments) into Intellicad's native format before proceeding to work with them.
To remove hidden clutter from your drawing for improved speed and stability:
1. Type the word PURGE then hit the ENTER key.
2. Type the letter A then hit the ENTER key.
3. SAVE the drawing before proceeding to work on it.
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by Lee Edwards:
<B>Intellicad can read a drawing from another cad program and convert the foreign file format on the fly before placing the drawing onto your monitor. Sometimes this conversion process loads your computer's brain with calculations and makes it seem slow.
THANKS FOR YOUR REPLY!!! I WILL GIVE IT A TRY.. =)
