Snap to hatching
rawebb
rawebb
Fri Aug 09, 2002 11:01 pm
Snap to hatching
#1 by rawebb
Is there a setting to disable the new (as of 6.1) feature of snapping to hatch lines?
Turning on "snap to nearest" and moving the cursor over something like a concrete hatch pattern has ... interesting ... results.
  • Sun Nov 20, 2005 12:04 pm
  • It is currently Sun Oct 11, 2026 1:37 am
