I have a problem when try to print a drawing with hidden lines. Is possible make this work?
I tried Icad 5.1 & Icad 6 trial but can't.
unfortunately, I gave a response without doing enough testing. As I only do 2D in Icad (all 3D is done in another application), I did not look into the problem sufficiently before responding. You are right, there is visable distortion when printing in hidden line mode. I have not been able to find a way around it. Unless someone can say otherwise, I will have to count it as a bug.
