line weight
Posted: Fri May 06, 2005 5:22 am
by earthshaker
I looked at the help file and cannot find a way to change line weight for a given drawing perhaps I can create a new linetype that has the weight I need could you point me in the right direction?
Posted: Fri May 06, 2005 7:02 am
by davep
Type at the command prompt: LWEIGHT
Or from the pull down menus find "Drawing setting" and select the "Display" tab.
Posted: Fri May 06, 2005 7:54 pm
by earthshaker
Tried lweight at the command prompt, gor "unable to recognize command try again"
Posted: Sat May 07, 2005 9:31 am
by CW
Works here. What version are you using? I don't remember when it was introduced but lineweight is a relativly new feature.
Posted: Sat May 07, 2005 1:15 pm
by earthshaker
version 2001
Posted: Sat May 07, 2005 3:44 pm
by CW
Lineweight by color. Set it in the print dialog. Won't show on screen as diferent lineweights but will print that way.
[This message has been edited by CW (edited 05-07-2005).]
