Embedded Object Borders
austenq
austenq
Sat Jan 15, 2005 12:01 am
#1 by austenq
Hello,
I'm running IntelliCAD 5.1 SE, and have a bitmap of our company logo inserted in the drawing. My question is: Is there is any way to keep a border from appearing around the object when plotting?
Thanks in advance,
Austen
  • Tue Apr 26, 2005 9:22 pm
davep
davep
Mon Apr 23, 2001 11:01 pm
Peoria, Illinois, USA
#2 by davep
Turn the image frame off.
This command should be with the image commands.
  • Wed Apr 27, 2005 7:05 am
  • It is currently Sun Oct 11, 2026 8:15 am
