5.0 v. 5.1
Posted: Tue Mar 08, 2005 5:01 pm
by LenR
I am evaluating Intellicad to replace AutoCAD LT 2005. I have a version 5.0 from one vendor and the version 5.1 from CMS.
Version 5.0 opens all my test files fine but 5.1 does not display all the views on one drawing. That same drawing when saved and reopend will crash Intellicad 5.1 but saves and opens fine in 5.0.
Drawing has been Audited and Purged in AutoCAD.
ANyone else have these issues?
Posted: Wed Mar 09, 2005 11:02 am
by chrisd
I have some problems with certain AutoCAD v2000 files in CMS IntelliCAD 5.1.5. In some cases the files open, and the document is empty, or IntelliCAD freezes up. Opening the same files in CMS IntelliCAD 4.1 works fine. If I explode the blocks in 4.1, and resave the file, I am usually able to open the file in 5.1. However, some of the files with the exploded blocks that open in 5.1 will not save or export from 5.1.
I am working with ACIS objects, so I suspect the version of ACIS may have changed from 4.1 to 5.1.???
Chris
Posted: Wed Mar 09, 2005 11:07 am
by chrisd
Chris
Posted: Wed Mar 09, 2005 12:45 pm
by LenR
I am not sure what ACIS is.
My drawing has only paper space with drawing border - model space with a bunch of tables imported from Excel and pasted in as AutoCAD entities.
I tried converting the file to 2000 and R14 format and exploding everything.
Posted: Wed Mar 09, 2005 1:41 pm
by chrisd
Len,
ACIS is the solid modeling component, so this is not related to your problem. My knowledge of IntelliCAD and ACAD is limited, so, if you've exploded everything and saved as earlier versions and still are not having any success, hopefully a more experienced user will be able to give you some assistance.
Chris
