Saving drawings with multiple layout's
Carlos Williams
Carlos Williams
Fri Jan 28, 2005 12:01 am
Campinas, Sao Paulo, Brasil
#1 by Carlos Williams
When editing and saving Autocad drawings with two or more layout's in Icad 5, it seems that only one layout is saved.
Has anyone had this problem?
  • Fri Jan 28, 2005 6:08 am
  • It is currently Sun Oct 11, 2026 12:04 pm
