Multiple lines when inserting blocks
dynamis
dynamis
Mon Jan 26, 2004 12:01 am
São Paulo, SP, Brazil
#1 by dynamis
Hello!
Im having problems when inserting blocks from other drawings. It apears that the lines are inserted many times (3 or 4) on the same location, making the drawing file size larger. Has anyone encounter the same problem?
Thanks!
  • Wed Oct 13, 2004 7:45 am
  • It is currently Sun Oct 11, 2026 3:16 am
