"Basic" dimensions
Does ICAD support "Basic" Dimensioning? I am talking about Geometric Dimensioning and Tolerancing. "Basic" dimensions are dimensions with a box drawn around them. If it is supported how do you specify, in dimension settings, that you want "Basic" dimensions?
cadmonster,
Yes, this can be done in VBA.
You can use the BoundingBox Method to find the lower/upper points and draw a rectangle around the dimension text.
