iCAD v15 failed creation of custom layouts for print
ant64
ant64
Thu Apr 04, 2019 5:05 pm
#1 by ant64
Hi i'm an updater from v12.1 and had to uninstall v15 (manteinance updated) and run back to v12.1 cause with v15 it's impossible to create new custom layouts with all the driver in my pc (pdf24-microsoft-dwg2pdf). That's foundamental for my future works. Due to this issue the v15 i purchased is totally useless.
Please help me!
  • Fri Oct 09, 2026 8:51 am
  • It is currently Fri Oct 09, 2026 5:05 pm
