How to Create, Edit, and Save Texture-Based Material Archives in ARTISAN for CMS IntelliCAD
If you are looking to build up and organize your texture-based material archives in ARTISAN, We've put together a quick step-by-step guide based on the documentation.
1. Preparing Your Textures
> Start by obtaining a set of high-resolution texture files.
> Ensure your files are "tileable" whenever possible. Because the texture file repeats across the surface, tileable images ensure the junctions between repeats remain invisible.
> Make sure your files are in one of the supported formats: jpg, bmp, tga, tif, or png.
> Keep track of the physical size of your texture sample in real-world units (like cm or inches). You will need this data to properly scale and repeat the texture over a large surface.
2. Applying and Editing in ARTISAN
> Open your model in ARTISAN.
> Navigate to the Material list and select the 'User Defined and Other' category.
> Apply the 'Texture' material to a part of your model. You will see a red grid appear, indicating it is a user-defined texture.
> Right-click the material on your model and select 'Edit Material'.
A quick note on naming and color: Don't worry about the material's name at first; it transfers over from the CAD system. Also, the 'Colour' field is disabled for standard Textures. If you have a set of textures that only vary by color, apply the 'Filtered Texture' material instead. This blends your chosen color with the image file, so it works best if you use a white version of the base texture.
> Click the 'Edit...' button to locate and select your texture file.
> Enter the real-world width and height dimensions of the image. The real-time view will update automatically to show the effect as you click or tab between the fields.
> Leave the other controls alone for now and click 'OK' to close the dialog.
3. Creating the Archive
> Right-click your newly configured material and select 'Add Material to Archive'.
> Choose a name for the material. If this is the very first material in your archive, click 'Create' to generate the new archive.
> To view your new archive, click the 'Star' icon located in the Material selector.
> You can store any number of materials and have any number of archives available under this Star icon.
> Pro-tip: You can also create user-defined materials by applying a standard ARTISAN material, editing it, and then saving it to an archive under a new name.
4. Exporting and Sharing Archives
> Archives can be easily exported and transferred to another ARTISAN user.
> Click the 'Export Archive' button (found under the Star icon) to pack all necessary data for those materials into a single file.
> To load an archive from someone else, simply use the 'Import...' option located in the Archive menu.
