How to enable VBA and run VBA 7.1 IDE on CMS IntelliCAD
Posted: Thu Mar 26, 2026 11:40 am
by CMS Inc
Microsoft Visual Basic for Applications (VBA) 7.1 is available as an optional component for CMS IntelliCAD. You can download the installer directly from the "Downloads" section of our website. Note: If you have Microsoft Office 365 installed locally, VBA 7.1 may already be present on your system.
How to Enable VBA:
Run as Administrator: Right-click the CMS IntelliCAD desktop shortcut and select "Run as administrator" (This is required for initial activation).
Enable the Variable: At the command bar, type VBAENABLE and set it to ON.
Restart: Close and restart CMS IntelliCAD, again using the "Run as administrator" option.
Verify: Type _VBA in the command bar. The VBA IDE should now open.
