ENTITY SNAP TRACKING
THe feature entity snap traking still has not improved. Still no match to Autocad. They fixed something (little as i have felt it) but still hard to match obejcts using it. one tracking is not present to match 2 objects. You just arrive to mach the objects by drawing reference lines, time consuming.
Re: ENTITY SNAP TRACKING
Hello,
Screen Shot 02-04-26 at 07.55 PM.PNG (10.84 KiB) Viewed 3069 times
I am encountering the same problem:
I want to align a circle and a rectangle perpandicularly (attached piece).
When I obtain a displacement point that seems to suit (appearance of a cross), I realize that there is often a small error in position on the axis of displacement of the entity.
I tried with the 'Align' or 'Move' command with the same result.
I tried several hooking parameters without obtaining an absolute result.
Junny wrote: ↑
Mon Nov 03, 2025 10:48 am
With the updated CMS IntelliCAD 14.1 version snap tracking works generally well. If you have a specific scenario to report then you can do it at this forum and if there's a bug we'll address it. Simple as that.
