Windows 10 upgrade to windows 11
omo_murray
omo_murray
Fri Feb 09, 2024 7:59 pm
#1 by omo_murray
A simple question I hope.
If I uprade from Windows 10 to windows 11, will my CMS IntelliCAD 10 PE still work?
  • Fri Oct 03, 2025 12:40 am
QuanNguyen
Sat Nov 09, 2019 6:50 pm
Re: Windows 10 upgrade to windows 11
#2 by QuanNguyen
The simple answer is that IntelliCAD 10 works on Windows 11.
But you should update the IntelliCAD to the latest version to use the new features and fix the bugs.
  • Sat Oct 04, 2025 7:26 am
omo_murray
omo_murray
#3 by omo_murray
Thanks! I'll give it a go. :)
  • Sun Oct 05, 2025 8:15 pm
