Points Collection
Posted: Mon Sep 29, 2025 3:37 pm
by JEL57
I am attempting to add points to a points collection and can't figure out how to do it. Following is the code:
Dim PointsList As New Points, intReturn As Integer
For j = 0 To 15
'use inspnt variable to set coords for each point
InsPnt.x = Coords(j, 0)
InsPnt.y = Coords(j, 1)
InsPnt.z = 0
' InsPnt = PointsList.Add(Coords(j, 0), Coords(j, 1), 0) <-- I tried this line of code
PointsList.Add = (InsPnt) <-- and then this line of code.
Next j
Both lines of code I tried return Run-Time Error '438': - Object doesn't support this property or method.
I cannot find a good reference manual for the intelliCAD objects and methods.
Is there a reference manual available anywhere?
Any help with the code and locating a reference manual would be appreciated.
Jack
Re: Points Collection
Posted: Mon Sep 29, 2025 6:40 pm
For j = 0 To 15
InsPnt.z = 0
Next j
Jack
Please refer to the simple code for adding a polyline.
Public Sub test()
    Dim PointsList As Points
    Set PointsList = Library.CreatePoints
    For j = 0 To 2
        Call PointsList.Add(j, j + 0.2, 0)
        Call PointsList.Add(j, j - 0.2, 0)
    Next j
    Dim pl As Polyline
    Set pl = ActiveDocument.ModelSpace.AddPolyline(PointsList)
Posted: Thu Oct 02, 2025 9:36 am
by JEL57
Thanks for the sample code. I was able to get my routine that draws steel wide flange beams working.
Is there any command reference available anywhere for the intelliCAD implementation of VBA?
