Why the frozen layers will come out again when ETransmit drawings
verdant
Mon Oct 14, 2024 1:03 pm
#1 by verdant
Hi everyone,
As title, when I ETransmit drawings and bind Xrefs,
the frozen layers in original drawings will be thawed in ETransmited files,
I need it to be frozen,
how can I fix it?
  • Thu Sep 04, 2025 12:02 pm
  • It is currently Sun Oct 11, 2026 6:49 pm
