Version 14 PE+
J.Fey
J.Fey
Sat May 31, 2025 12:19 pm
Version 14 PE+
#1 by J.Fey
Hallo weiß einer wieviel ein Update auf Version 14Pro + von Version 13.1PE+ kostet und ist die Version auf Deutsch.
M.F.G.J.Fey
  • Sun Aug 24, 2025 6:04 am
sln8458
Mon May 19, 2003 11:01 pm
Re: Version 14 PE+
#2 by sln8458
check here: > https://www.intellicad.org/intellicad-14.0-release <
  • Fri Aug 29, 2025 12:52 am
Hi i&#039;m an updater from v12.1 and had to uninstall v15 (manteinance updated) and run back to v12.1 cause with v15 it
I installed maintenance build 15.0.587.175583.PE+.VC17.x64.CMS150, but the problem persists; it doesn&#039;t happen cons
