  4. AutoLisp/SDS
Hyperlink to the block
  4. AutoLisp/SDS
vladikall
vladikall
Sun Aug 17, 2025 11:25 pm
#1 by vladikall
Hello, I'm asking for help from the community. I need a list that allows me to create a hyperlink from text (mtext) to a block in the model/sheet. It's similar to the function in Revit where clicking on an object in the specification displays it in the model.
  • Sun Aug 17, 2025 11:30 pm
Return to “AutoLisp/SDS”
  • It is currently Sat Oct 10, 2026 5:03 pm
