  4. AutoLisp/SDS
error: ActiveX Server returned the error: unknown name: GETDYNAMICBLOCKPROPERTIES
  4. AutoLisp/SDS
randomxs
Tue Nov 05, 2024 1:28 pm
#1 by randomxs
Hi all, I'm new to IntelliCAD but old to Acad.
(vlax-invoke ven 'GetDynamicBlockProperties) works in acad's vlisp, but throws the subject error in Intellicad.
Is there a workaround?
  • Thu Jul 17, 2025 10:04 am
QuanNguyen
Sat Nov 09, 2019 6:50 pm
Re: error: ActiveX Server returned the error: unknown name: GETDYNAMICBLOCKPROPERTIES
#2 by QuanNguyen
I'm not sure, but it seems IntelliCAD doesn't fully support Dynamic Blocks in Lisp functions.
Try using the .NET API instead.
  • Fri Jul 18, 2025 2:52 am
Return to “AutoLisp/SDS”
