VBA Groups
I cannot get the group.appenditems to work. I have tried
Sub testgroup()
    Dim icadApp As IntelliCAD.Application, icadDoc As IntelliCAD.Document
    Dim iCadLibrary As IntelliCAD.Library
    Set icadApp = GetObject(, "icad.application")
    Set icadDoc = icadApp.ActiveDocument
    Set iCadLibrary = icadApp.Library
    Dim myGroup As IntelliCAD.Group
    Set myGroup = icadDoc.Groups.Add("MyGroupName2")
'try one - creates an array of "entities"
    ReDim ssobjs(0 To 8 ) As IntelliCAD.Entity
    For i = 990 To 998
        Set ssobjs(i - 990) = icadDoc.ModelSpace.Item(i)
    Next i
    myGroup.AppendItems ssobjs   ' FAILS HERE
'try two  - creates an array of variants
    ReDim ssobjsvar(0 To 8 ) As Variant
    For i = 990 To 998
        Set ssobjsvar(i - 990) = icadDoc.ModelSpace.Item(i)
    Next i
    myGroup.AppendItems ssobjsvar   'FAILS HERE
'try 3 - try single entity
    Dim myobj As IntelliCAD.Entity
    Set myobj = icadDoc.ModelSpace.Item(990)
    myGroup.AppendItems myobj    'FAILS HERE
'try 4 - try single item
    myGroup.AppendItems icadDoc.ModelSpace.Item(990)
'try 5 - draw and add line (have also tried by drawing 2 lines and adding each as csv, as an array etc
    dim line1 As Object
    Set line1 = icadDoc.ModelSpace.AddLine(ptLineStart, ptLine1End)   'points defined elsewhere - line is valid
    line1.Update
    myGroup.AppendItems line1   'FAILS HERE
end sub
I've run out of ideas - any one got any suggestions? thanks!!
Re: VBA Groups
Hi Richard,
Here's the simple code to add the entities in ModelSpace to a group.
Sub Example_AppendItems()
    ' This example creates a group and appends the objects to the group.
    Dim groupColl As Groups
    Set groupColl = ActiveDocument.Groups
    ' Create a group named "TEST" in current drawing
    Dim testGroup As Group
    Set testGroup = groupColl.Add("TEST")
'    MsgBox "A new group called " & testGroup.Name & " has been added to the Groups collection.", vbInformation, "Groups Example"
    ' Iterate through the model space collection.
    ' Collect the objects found into an array of objects to be added to the group.
    ReDim appendObjs(0 To ActiveDocument.ModelSpace.Count - 1) As Entity
    Dim I As Integer
    For I = 0 To ActiveDocument.ModelSpace.Count - 1
        Set appendObjs(I) = ActiveDocument.ModelSpace.Item(I)
    Next
    ' Add the array of objects to the group
    testGroup.AppendItems appendObjs
Re: VBA Groups
Hi QuanNguyen, thanks so much for the fast and informative reply.
That code crashes IntelliCAD (completely - window disappears and Windows "send error report" shows up) at the testGroup.AppendItems appendObjs line
I have tested it on a second computer/install/license of IntelliCAD and seen the same.
Both versions tested are CMS IntelliCAD 11.1 64bit.
Many thanks, Richard
Re: VBA Groups
richardss wrote:
Tue Mar 11, 2025 7:19 am
Sub testgroup()
    For i = 990 To 998
    Next i
    For i = 990 To 998
    Next i
    dim line1 As Object
    line1.Update
end sub
Hi richard
this is the only solution I could find
Sub dummy(gr As IntelliCAD.group, icadDoc)
Dim OB(0) As IntelliCAD.Line
Dim apo As New IntelliCAD.point, se As New IntelliCAD.point
'  if there are no members the routine tries to add one
 '  An error occurs, it blocks with "on error resume  next"
  ' then error clearing and you can add anything"
If gr.count > 0 Then Exit Sub
se.X = 1
Set OB(0) = icadDoc.ModelSpace.Addline(apo, se)
OB(0).Update
On Error Resume Next
    gr.AppendItems OB
    If Err Then
        Err.Clear
        gr.AppendItems OB
    End If
    gr.Update
    gr.RemoveItems (OB)
    OB(0).delete
Sub testgroup()
    Dim myGroup As IntelliCAD.group
    ' this is the only solution I could find"
    '  after the first error you can add items
    dummy myGroup, icadDoc
    ReDim ssobjs(0 To 8) As IntelliCAD.Entity
    For i = 990 To 998
    Next i
    myGroup.AppendItems ssobjs   ' no FAILS HERE
