  4. VBA, . NET & IRX
Object.ObjectId in properties
  4. VBA, . NET & IRX
Shank
Shank
Fri Dec 20, 2024 7:22 am
#1 by Shank
Hi, I'm finding ObjectID in properties of but only have ObjectName
https://www.progesoft.com/products/prog ... ct/members
I saw in AutoCad, they have ObjectID and ObjectName.
https://help.autodesk.com/view/OARX/202 ... 4DB223053F
Did I miss anything ?
I want get ObjectID from Object and get Object from ObjectID. Any Ideas?
  • Fri Dec 20, 2024 7:31 am
QuanNguyen
Sat Nov 09, 2019 6:50 pm
Re: Object.ObjectId in properties
#2 by QuanNguyen
Hi Shank,
Not sure, but maybe IntelliCAD doesn't supply the ObjectId property in VBA.
We can use the Handle property instead.
Using HandleToObject to find an object with the given handle:
Public Function HandleToObject( ByVal Handle As String) As Object
  • Fri Dec 20, 2024 7:50 pm
Shank
Shank
#3 by Shank
The algorithm will run very slowly when the number of objects exceeds 10,000 if "select all" is used. Do you have any other methods?
And I want download IntelliCAD developer reference.chm, but can't find the link.
  • Sat Dec 21, 2024 12:49 am
Shank
Shank
#4 by Shank
All my bad, I found it. Thank you
  • Sun Dec 22, 2024 4:37 pm
Return to “VBA, . NET & IRX”
  • It is currently Thu Nov 26, 2026 9:23 am
