  4. New User
Image Manager still not working in 13
  4. New User
Bruno
Bruno
Mon Sep 23, 2024 9:57 am
#1 by Bruno
I attached an image (.tif) to a drawing and changed Brightness resp. Contrast of the image, but applied adjustments to the image do no show up in the image itself. Is there any workaround ?
Bruno
  • Mon Sep 23, 2024 10:09 am
redova5966
redova5966
Fri Oct 04, 2024 4:37 am
Re: Image Manager still not working in 13
#2 by redova5966
One workaround you can try is to save the adjusted image separately and then re-attach it to the drawing. This should ensure that the brightness and contrast adjustments are properly applied to the imagetime calculator.
  • Fri Oct 04, 2024 4:41 am
lossstarry
lossstarry
Wed Oct 09, 2024 3:26 am
#3 by lossstarry
Open the .tif file in a dedicated image editing software like Photoshop, GIMP, or even a basic editor. Make your brightness and contrast adjustments there, save the changes, and then import it back into your drawing.
https://www.forums.intellicadms.com/mem ... b6c74d8865geometry dash
  • Wed Oct 09, 2024 3:30 am
Return to “New User”
  • It is currently Sun Oct 11, 2026 7:17 pm
