Changes to 12.1 causes issues with relative/absolute inputs.
What has changed between 12.0 and 12.1?
While my problem is highlighted in my piping lsp add-on, the issue is NOT lisp related I believe.
Here I have created a line from 0,100,0 to 100,0,0 via lsp, but when I 'list' the line it is not from/to these co-ordinates.
Command: _line
ENTER to use last point/[Follow]/<Start of line>: 0,100,0
[Angle/Length]/<End point>: @100,0,0
[Angle/Length/Follow/Undo]/<End point>:
Command:
Opposite corner:
Command: _ERASE
1 found
Command:
Opposite corner:
Command: LI
--------------------------- LINE ----------------------------------
Handle: 67B
Current space: Model space
Layer: 0
Color: BYLAYER
Linetype: BYLAYER
Line weight: BYLAYER
From point: X = 0 Y = 0 Z = 0
To point: X = 100 Y = 0 Z = 0
Length: 100
Angle in UCS XY plane: 0
Delta values: X = 100 Y = 0 Z = 0
Anyone have a clue why this is??
Re: Changes to 12.1 causes issues with relative/absolute inputs.
Here is another example:
Create a cylinder of radius 14.6 and a height of 265 at WCS origin
code:
(command "_cylinder" "0,0,0" (* 0.1 FTF#) (rtos  OBORE#))
FTF# = 146
OBORE# = 265
result:
Command: _cylinder
[Elliptical]/<Center of base of cylinder> <0,0,0>: 0,0,0
[Diameter]/<Radius of cylinder>: 14.6
[Center of second end/2Point]/<Height of cylinder>: 265
Command: '_PMTHIST
Command: LI
------------------------ 3DSOLID ----------------------------------
Handle: 5D1
Layer: 0
Color: BYLAYER
Linetype: BYLAYER
History: Record
Show History: No
Bounding Box:
Lower Bound: X = -14.6 Y = -14.6 Z = 0
Upper Bound: X = 14.6 Y = 14.6 Z = 265
QuanNguyen wrote: ↑
Thu Apr 04, 2024 9:14 pm
Hi Steven,
Maybe the issue is due to using commands in the lisp routine.
Try to turn off the Snap before calling any commands.
Regards.
Hi Quan,
Thanks, but I have tried that both in the code and manully via setting.
I have noticed this morning that using:
(setvar "OSMODE" 0)
(setvar "OSMODE" 7)
Has NO effect on tha snaps shown in the snaps toolbar on the side of my screen!!?
I have solved the problem :)
Quan was correct :wink:
I found an additional OSMODE statement (instruction) within my code which I had forgotten about which was overighting the changes I was trying to make.
This was also impacting my manual changes via settings.
Thanks to Quan, I re-checked this morning and found my earlier error, though I'm not sure why this did not surface in 12.0 but solved now.
