It seems as though IntelliCAD PE 12 already has been out for quite a few months now, but IntelliCAD PE Easy Run is still stuck at version 11.1. It would be great if the company could provide some guidance on how long it takes for a new version to be made available to Easy Run customers. Part of the reason I purchased this version was the understanding that it would be always up-to-date. I do not necessarily need the features of 12, but I would like to understand if the version will ever be made available or, generically, how long one should expect to wait before Easy Run customers "catch up" to the normally installed based customers.
Regards.
Re: When will IntelliCAD PE Easy Run be updated to version 12
#2Very soon, and it will be updated to 12.1
#3OK, thank you for the information/confirmation. Just so I can set my expectations for future major version changes, is it fair to say that the release to Easy Run is about 6 months behind the "traditional" product?
#4As an Easy Run customer, I'm curious about the timeline for the next version update. While I don't necessarily need the new features, it would be helpful to understand when Easy Run customers can expect to catch up to the main IntelliCAD PE 12 release. Any guidance on the typical update cycle would be appreciated.
omegle chat with strangers
#5I can set my expectations for future major version changes. Any announcements on timing for an upcoming new version?
#6CMS IntelliCAD is on version 12.1 since February , 2024.
CMS IntelliCAD PE EASY RUN is also on 12.1 version since then; licensed users can get it at https://run.intellicadms.com
#7I completely understand your frustration. It does seem like there’s a gap between updates for IntelliCAD PE and IntelliCAD PE Easy Run. It would indeed be helpful if the company could provide some clarity on their update schedule for Easy Run customers. You’re not alone in wanting to know how long it typically takes for these versions to sync up. It’s reasonable to expect some guidance, especially since staying up-to-date was a part of why you chose this version. Hopefully, the company can provide more information soon to address these concerns.hill climb racing
#8If you still do not receive a satisfactory answer, it might be useful to consider if there are alternative CAD software options that provide more consistent update schedules in line with your needs.
Floyd Wolf
geometry dash - where you test your own speed limit!
