I'm a new user from Italy.
I would know if is it possible to change the icons of the toolbar, loading alternative pictures or icon library, thanks.
Re: Command Icon
#2Hi
Yes it is possible.
Go to TOOLS, down to Customise UI...
(it might be a good ised to read the HELP info on Customize.
Here you can change you icons.
Ciao
Yes it is possible.
Ciao
www.stylemarkdesigns.co.uk
Re: Command Icon
#4I used png images and it works as you can see on the attached images.
- Attachments
- Icons.png (194.17 KiB) Viewed 1339 times
