Cond help
Having trouble setting a cond statement.
When the value of 'eit' is anything above '0' I want to create the insulation entities. [within the (progn....)]
If 'eit' is zero I want to skip this step and go to (INS_MB)
The following code does not work & I can't see my error(s)
(defun DRAW_INS ()
; Draw Insulation recangle
	(cond (/= eit 0)
	(command "_Rectangle";
						  (strcat (rtos EIXOO#) "," (rtos EIYOO#) ",0" )
						  (strcat "@" (rtos eitx#) "," (rtos eity#) ",0" ) "")
	(command "_fillet" "R" eit# "")
	(command "_fillet" "P" "L" "")
		(setq ENTZ1 (entlast))
;Extrude Insulation Shell
	(command "_extrude" ENTZ1 "" dis "")
		(setq ENTZ3 (entlast))
	(command "_extrude" ENTZ2 "" dis "")
		(setq ENTZ4 (entlast))
	(command "_subtract" ENTZ3 "" ENTZ4 "")
		(setq ENTZ5 (entlast))
	(command "_change" ENTZ5 "" "P"	"la" "Insulation" "")
		(ssadd ENTZ5 SS)							; ADD TO SELECTION SET
	);end progn
	);END COND
	(INS_MB)
) ;end DRAW_INS
Re: Cond help
Hi Steve,
The "(cond (/= eit 0)" should be "(cond ( (/= eit 0)"
Please refer this :
(defun DRAW_INS ()
 (cond
   ((/= eit 0)
          ; do something
      ) ;end progn
    ) ; end (/= eit 0)
   );END COND
  (INS_MB)
) ;end DRAW_INS
Re: Cond help
Thanks Quan,
However if I add the '(' as you suggest I am missing the closing ')' ??
edit:
scrap that, I just noticed the ' ) ; end (/= eit 0)'
Re: Cond help
Sorry Quan, but your change has not improved things :(
I'm trying to create a section of Rectangular ductwork, complete with flanges at both ends.
In some cases the user will require insulation and in others they will not.
So by filtering via the External Insulation Thickness (eit), I want to either create the insulation or skip that section
I've attached the full code below.
rduct.zip
(3.31 KiB) Downloaded 362 times
