Layer Transparency
Anyone know how to set the layer transpaarency in lsp??
Ihave tried exporting a file to dxf to find the code but the dxf files are not as they used to be :(
Re: Layer Transparency
Hi Quan, Happy New Year :) :)
Thanks for the link, sadly that went way over my head :(
I am creating a new layer & setting it's attributes
This is where I am so far:
	(entmakex
  		(list
			(cons 0 "LAYER")							;defines create new layer
			(cons 100 "AcDbSymbolTableRecord")
			(cons 100 "AcDbLayerTableRecord")
			(cons 2 "Insulation")							; Layer name
			(cons 62 2)               						; Layer color
			(cons 440 65)               						; Layer Transparency
		);end list
	);end entmake
The layer is created, colour set to 2 (yellow) but the transparency (code 440) is ignored. :(
Please try this:
(defun C:entmakeLayer ()
  (regapp "accmtransparency")
  (entmakex
    (list
      (cons 0 "LAYER")
      (cons 2  "LayerTranparence") 	;layer name
      (cons 6  "Continuous") 		;linetype
      ;(cons 370  LWeight) 		;lineWeight
      (cons 62  2) 			;layer color
      (cons 70 0) 			; on, unlocked, thawed
      (cons 290 1) 			;Plot/No Plot : 0->No plot
      (cons -3	    			;transparency
	    (list(list "accmtransparency"
		       (cons 1071 (LM:trans->dxf 61))	) ) )
  (princ))
Hi Quan,
Thanks for the code.
I had to go to the thread you kinked to as part of your code failed.
It errored here : LM:trans->dxf
copied this and all is good now :)
(defun LM:trans->dxf ( x )
    (logior (fix (* 2.55 (- 100 x))) 33554432)
Most of your code I understand, but this confuses me, can you explain a little please?
			(cons -3	    						; transparency
				(cons 1071 (LM:trans->dxf 65))	) ) )
This is where the codes is atm.
I've also added a check for the layer existance.
(defun MKLAY_INS ( / )
	(if (tblsearch "layer" "Insulation") (DRAW_CD)
	(entmakex
  		(list
;			(cons 6  "Continuous") 					; linetype
;	    		(cons 370  LWeight) 					; lineWeight
;   			(cons 70 0) 						; on, unlocked, thawed
;			(cons 290 1) 						; Plot/No Plot : 0->No plot
				(list(list "accmtransparency"			; transparency
				(cons 1071 (LM:trans->dxf 65))	) ) )		; transparency
		);end list
	);end entmake
	);end progn
	); end If
	(DRAW_CD)
I am having issues with the code below, in that if the kayer 'Insulation' does not exist the layer is created
and everyting works fine.
However
If the layer exists everything executes as expected, but at the end the (CD_SHAPE) is exucuting a second time??
; Create Insulation Layer + layer attributes
(defun MKLAY_INS ()
(princ "\n start MKLAY_INS ")
	(if (tblsearch "layer" "Insulation")(CD_SHAPE)
	(entmakex
  		(list
;			(cons 440 "65")               			; Layer Transparency
				(cons 1071 (LM:trans->dxf 65))	) ) ); transparency
		);end list
	);end entmake
	);end progn
	); end If
	(CD_SHAPE)
) ;end MKLAY_INS
I then tried to add this code, commenting out the 'IF' statement above. This works fine except, it has an issue where the color for layer 'Insulation' is changed back to white (7)
;Check if layer 'insulation' exists
(defun CK_LAY ()
	(CD_SHAPE)
	(MKLAY_INS)
	):END IF
);END CK_LAY
full lsp file attached.
CDUCT-5.zip
(2.33 KiB) Downloaded 425 times
