How to change print color of doors & stairs inserted with the standard tool palettes
The standard tool palette with doors en walls work magnificient (I use it for 2D drawing only at the moment).
It works almost a fast as drawing single line floorplans. NICE !
But the doors are drawn in yellow color.
The problem I have is that the yellow color isn't visible enough after printing.
When I change the color in the layer manager(both the color and the VP color), the door color doesn't change.
Typically I use one or more viewports in the layout tab en change the color in that viewport specifically.
Putting the doors in a separate layer and change the layer color didn't help either.
Save the drawing and use it as an XREF in another drawing, and than change the colors didn't help also.
Using this build: 11.1.435.145443.PE+.VC16.x64.CMS111
The only solution that I found so far, is to explode the door, but that is not the idea, because it may stay be required afterwards to change the door location.
Many thanks in advance.
