I've made progress.
First I should have used 'popup' list:
- Ebow dialog2.png (8.55 KiB) Viewed 16066 times
Still unable to change the text to bold
However I now have a new issue, searched all day on the internet, just confused myself even more
Current problem, how do I capture the selected value from the popup list
I can get the 'position' in the list, but not the actual value
Current ID is: = 250
Current WT is: = 1
Current CL Rad is: = 125
Current angle is: = 4
lsp code:
(defun C:CDUCTE ()
(setq alist (list "" "15" "30" "45" "60" "90"))
(setq dcl_id (load_dialog "CDUCTE.dcl"))
(if (not (new_dialog "CDUCTE" dcl_id))
(exit)
);if
(start_list "aglist")
(mapcar 'add_list alist)
(end_list)
(if #val
(set_tile "aglist" (itoa (setq val #val)))
(set_tile "aglist" (itoa (setq val 0)))
);if
;--------------SET INITIAL DEFAULT VALUES FOR DISPLAY------------------;
(setq ID 100
WT 1.8
CL 100
mm_ins "mm_"
);setq
(set_tile "ID1" "100") ;SET INITIAL VALUE
(set_tile "WT1" "1.8") ;SET INITIAL VALUE
(set_tile "CL1" "100") ;SET INITIAL VALUE
(mode_tile "ID1" 2) ;SET FIRST ENTRY BOX
(defun CD_SHAPE ()
(princ (strcat "\nCurrent ID is: = " id " "))
(princ (strcat "\nCurrent WT is: = " wt " "))
(princ (strcat "\nCurrent CL Rad is: = " cl " "))
) ;end CD_SHAPE
;----------------------------ACTION TILE STATEMENTS---------------------;
(action_tile "aglist" "(setq val (atoi $value))")
(action_tile "cancel" "(done_dialog)" ) ;if cancel selected do this
(action_tile "accept"
(strcat
"(progn (setq ID (get_tile \"ID1\"))"
"(setq WT (get_tile \"WT1\"))"
"(setq CL (get_tile \"CL1\"))"
"(done_dialog))"
); END ACCEPT ACTION TILE
;-----------------------------END OF ACTION TILE STATEMENTS--------------;
; (defun DIALOG () continued
(start_dialog) ;start dialog
(unload_dialog dcl_id)
(CD_SHAPE)
; (princ (strcat "\nCurrent VERSION for the lisp file is: = " ver " "))
(princ (strcat "\nCurrent angle is: = " (rtos val) " "))
(princ)
);defun
;CODING ENDS HERE
As beforw ':' deleted due to website issues
DCL code:
CDUCTE : dialog {
label = "Cylindrical Duct Elbow Dimensions";
edit_box {
label = "&Internal Diameter (mm)";
is_bold = true;
key = "ID1";
edit_width = 5;
allow_accept = true;
edit_box {
label = "&Wall Thickness (mm)";
key = "WT1";
edit_width = 5;
edit_box {
label = "&Center Line Radius (mm)";
key = "CL1";
edit_width = 5;
row {
column {
text { label = "Choose Swept Angle"; width = 20;}
column {
popup_list {
key = "aglist" ;
width = 8;
fixed_width = true;
list = "";
ok_cancel ;
text_part {
label = "Designed and Created";
text_part {
label = "by Steve Nichols";
