Re: MTEXT and automatic SHX font substitution
apa wrote:
Mon Nov 20, 2023 3:44 am
I have a custom-made SHX font with greek and other special characters. It works fine with TEXT, however MTEXT automatically substitutes it with a ttf font for non standard latin characters. skibidi toilet
Any suggestions?
When using custom SHX fonts in AutoCAD, MTEXT might automatically substitute non-standard Latin characters with a TrueType Font (TTF) because SHX fonts typically do not support characters beyond the basic Latin set. This substitution can occur when the characters in the MTEXT exceed the capabilities of the SHX font.
I have a custom-made SHX font with greek and other special characters. It works fine with TEXT, however MTEXT automatically substitutes it with a ttf font for non standard latin characters.snaptik
Any suggestions?
In some cases, AutoCAD may prefer TrueType fonts for MTEXT. If the issue persists, you might consider converting your custom SHX font to TrueType format to ensure compatibility.
I have a custom-made SHX font with greek and other special characters. It works fine with TEXT, however MTEXT automatically substitutes it with a ttf font for non standard latin characters. geometry dash
Any suggestions?
You might want to try embedding your SHX font directly into the drawing or setting the MTEXT style to explicitly use your custom SHX font. Sometimes defining the font in the MTEXT style settings helps prevent automatic substitution by the software.
I have a custom-made SHX font with greek and other special characters. It works fine with TEXT, however MTEXT automatically substitutes it with a ttf font for non standard latin charactersgeometry dash breeze.
Any suggestions?
Some software may automatically convert fonts for non-standard characters, and this is usually due to their default settings. You can try double-checking your font settings in MTEXT or see if there is an option to keep your SHX font for special characters
Any suggestions? slope
If you need the features of MTEXT (like formatting), consider creating a custom TrueType Font (TTF) that includes the necessary Greek and special characters. Tools like FontForge can help you convert your SHX font to TTF and include the additional characters.
Thank you all for your suggestions.
I found that if you type the mtext content using a ttf font and after editing you change the font property to the preferred shx font, Intellicad does not substitute the font. Although it does substitute it as long as you edit it. So, before editing you must change the font back to ttf and after editing, again, to shx. It works, at least on Intellicad 13.0.
A simple work-around, but not a solution...
I have a custom-made SHX font with greek and other special characters. It works fine with TEXT, however MTEXT automatically substitutes it with a ttf font for non standard latin characters.big tower tiny square
Any suggestions?
One workaround to ensure that the correct font is used in MTEXT is embedding the SHX font by creating a single-line text with your SHX font and converting it to MTEXT after it's typed. This ensures the MTEXT keeps the SHX font, but it may have some limitations for extensive formatting.
