Just activated my licensee for the 1st time and after I open a new drawing and I go to insert a foundation wall. I get the error shown below. Is there something I need to turn on to activate it?
Re: Unable to Access Architectural Tools
#2Hi,
Which version of the IntelliCAD do you use now?
As I know, only the "IntelliCAD Premium Edition Plus" supports AEC entities such as walls, windows, doors, openings, stairs, railings & slabs, etc.
#4Please verify that the system variable "AECOBJECTS" is set to 1.
#5Hi Quan,
I have this same problem, noticed when I tried to load _steel, I get the same error.
I have PE+ (11.1.435.145443.PE+).
I'm hoping that release 12.0 solves this.
PS
I have reported the issue some time back [ID: 4709]
PS
www.stylemarkdesigns.co.uk
- Attachments
- no steel AEC.jpg (108.17 KiB) Viewed 4958 times
#6Hi Stephen,
I have the PE+ (11.1.435) too.
the AEC works as they are on my PC.
Please try to reinstall it again.
Regards.
Regards.
#7I did that, about 5 times, CCleaner between each one.
Still no change!!
Still no change!!
#8AECOBJECTS was showing off and I turned it on and no difference. Still not recognizing the commands.QuanNguyen wrote: ↑Tue Nov 14, 2023 6:10 pmPlease verify that the system variable "AECOBJECTS" is set to 1.
#9Do you get the dropdown menus as per Quan?BulkHT wrote: ↑Wed Nov 15, 2023 9:49 amAECOBJECTS was showing off and I turned it on and no difference. Still not recognizing the commands.QuanNguyen wrote: ↑Tue Nov 14, 2023 6:10 pmPlease verify that the system variable "AECOBJECTS" is set to 1.
or like mine?
#11UPDATE!!!!
I now have it working. I uninstalled the program and reinstalled it with "RUN AS ADMINSTRATOR" and now it is working. I may not have originally installed it as administrator.
