Piping add-on New feature not working all the time. ***SOLVED***
Posted: Fri Nov 10, 2023 5:23 am
I'm in the process of adding an extra feature to my piping add-on. (NOTE: images / sld's not completed yet)
Check Valves
CV dialog.png (104.38 KiB) Viewed 10750 times
I have progressed the first valve selection, Plain to the point of inserting the completed valve.
CV completed dialog.png (54.3 KiB) Viewed 10750 times
The code behind this works fine as I step through when checking, but when I try this addition in normal use it sometimes works and sometimes doesn't.
I get this error:
Command: _filletedge
Current settings: mode = TRIM, radius = 3.9000
Select an edge: [Chain/Loop/Radius]: R
Fillet radius <3.9000>: 3.90000
Select an edge: [Chain/Loop/Radius]: 357.5000,0,0
Press Enter to accept the fillet or [Radius]:
Command:
Select an edge: [Chain/Loop/Radius]: 357.5000,0,222.0000
Modeling Operation Error:
blends too complex to reorder.
Unable to fillet the 3dSolid.
error: Function cancelled
Command:
Command: '_PMTHIST
Here is the code (lines 9571/9572 in the attaced file):
		(command "_filletedge" "R" EXRAD# (strcat (rtos VRAD#) ",0,0" ) "" "" "")
		(command "_filletedge" "R" EXRAD# (strcat (rtos VRAD#) ",0," (rtos FTF#)) "" "" "")
https://www.dropbox.com/scl/fi/pyenmg61 ... zg0v2&dl=0
Any thoughts pls?
Re: Piping add-on New feature not working all the time.
Posted: Fri Nov 10, 2023 1:07 pm
by SPirou4D
Hi Steve,
One idea to search:
357.5000,0,222.0000 is X,Y,Z ?
Why 222.0000 ? is it the Z ?
Posted: Sat Nov 11, 2023 1:58 am
Hi Pat,
you had selected the 25" valve ?
That part of the code is applying a 'fillet radius' to the outer edges of a vertical cylinder.
Bottom edge 357.5000,0,0
Top edge 357.5000,0 222.0000
The cylinder is 222 high. (Z)
I have generated the valve body profile via Entmake & revolved that to create the body
However there are 2 areas that then require an infill to be added 180deg appart (12 & 6 Oclock)
In the code that sometimes fails I an creating these infills.
I had a thought overnight, which I will test today.
Posted: Sat Nov 11, 2023 6:29 am
So I think I have traced the issue,
Screen Zoom, ie if the screen is too far zoomed out the code does not select the individual 'edge' required.
When I am testing the code step by step I am zoomed in close to the origin (0,0,0) so I can actually see what is happening.
When I am testing the final completed code, as it is expected to be used, that is when the issue presents.
Is there a setting I can change to overcome this?
Re: Piping add-on New feature not working all the time. ***SOLVED***
Posted: Sun Nov 12, 2023 2:05 am
I think I have found a solution.
I have tried a number of different things, but these three together seem to have resolved the problem.
_osmode 0
pickbox 0
OSNAPCOORD now set to '1' (this could be the only one required)
