Toolbar 3-D box command vs menu 3-D box
If I draw a 3-D box using the menu command, the inputs are 1st corner, 2nd corner, height. If I enable the 3-D draw menu and select box from it, the inputs change to 1st corner, length, width, height rather then specifying the second corner.
Is there any way to change the toolbar command behavior so it works the same as the menu command????
Dale
