I've had this happen as well. It's either at opening or during execution of a simple command. It just hangs with no warning, no error window, no movement on the screen other than my mouse on other portions of the monitor beyond the IntelliCAD window, no tax on the processor, no increase in fan speed, no sign of anything.sln8458 wrote: ↑Tue Aug 15, 2023 7:56 amATM, my biggest issue is 'doing nothing'
Let me explain: I go to open a drawing, 3D model of a section of chemical plant, and Icad seems to opening the drawing then it stops - check task manager and the PC is idle (doing nothing) and the only way to progress is shutdown via task manager re-open Icad then use recover drawing and then it WILL open the same drawing.
I've been through the loop of uninstall/re-install, no improvement. atm I have put it down to having large files, the full site is over 2.5Gb!!![]()
Sadly Icad does not make full use of the multicores available, so saving takes upto 10 mins, so I have autosave at 30 so I have some working time between saving.
Re you working in 3D?
if so try setting the display graphics to: Intermediate open GL as apposed to Advanced open GL. I have found this improves stability for 3D working.
Re: Consistent Crashes
#16Architectural Building & Interior Designer, AutoCAD since 1995, ArchiCAD in 2007 then Revit since 2012
CMS IntelliCAD 11.1.435.145443.PE+.VC16.x64.CMS111
Dell Optiplex Intel(R) Core(TM) i9-10900 CPU @ 2.80GHz, Windows 11 Pro
