3D Piping Menu - FRENCH
Curtesy of Patrick Depoix
Here is Revision 2.3.1 with a FRENCH user interface
ALL blocks created now have the suffix 'mm' or 'inch' appended to the block name.
Piping part 1
link removed
Piping Part 2
link removed
Piping part 3
link removed
Instructions PDF (this is the PDF for version 2.3.0, (please ignore the version number)
link removed
Re: 3D Piping Menu - FRENCH
Hi Quan,
Most of the work was done by Patrick,
Tho' there were a few issues as a result of changes in the latest build (11.1.435) :(
Stay safe
Hi Patrick,
I have found an issue with Blind RTJ flanges in both English & French versions (code fixed)
I have not posted this update until I hear if you find anything else. :)
Here is Revision 2.3.2 with a FRENCH user interface
Correction to a rotation issue with RB BV's
Fillet Radii added to Equal & Reducing Tees at the junction of the Main Run and Branch.
Piping part 1
link Deleted
Piping Part 2
link Deleted
Piping part 3
link Deleted
link Deleted
I have deleted the files relating to the earlier version, so the links will not work.
Here is Revision 2.3.3 with a FRENCH user interface.
I have now added/enabled the Wafer Check Valves. These Dual Plate type, and are generally in accordance with API 594
Dim Files
LINK DELETED
Piping part 1
LINK DELETED
Piping Part 2
LINK DELETED
Instructions PDF
LINK DELETED
Due to an error in my code, this does not work with Verion 12.1.
LINK DELETED
Here is the latest files for Revision 2.3.3 ---- UPDATED FOR ICAD VERSION 13.0 - with FRENCH user interface.
french menu 2-3-3.png (59.87 KiB) Viewed 165961 times
Dim Files
https://www.dropbox.com/scl/fi/bsifjo91 ... tte2v&dl=0
Piping part 1
https://www.dropbox.com/scl/fi/lip6cj6q ... rwvjh&dl=0
Piping Part 2
https://www.dropbox.com/scl/fi/7nmj0gbn ... 8ebtu&dl=0
Instructions PDF
https://www.dropbox.com/scl/fi/fok6rbnb ... b8mjk&dl=0
