dwgprops vba
#1are the DWGPROPS information exposed through vba. I have set up custom textfields on my standard pspace template which uses variables in DWGPROPS. From what I can glean, ACAD does it through document.summaryinfo
Sub Example_SummaryInfo()
' Add standard properties
ActiveDocument.SummaryInfo.author = "Darthurs"
ActiveDocument.SummaryInfo.comments = "DWGPROPS example"
ActiveDocument.SummaryInfo.HyperlinkBase = "http://www.intellicad.org"
ActiveDocument.SummaryInfo.Keywords = "Building Complex"
ActiveDocument.SummaryInfo.LastSavedBy = "Ben"
ActiveDocument.SummaryInfo.RevisionNumber = "Build 11.1.435"
ActiveDocument.SummaryInfo.subject = "SummaryInfo"
ActiveDocument.SummaryInfo.title = "CMS IntelliCAD"
Dim author As String
Dim comments As String
Dim hyperLink As String
Dim keyWord As String
Dim lastSave As String
Dim revision As String
Dim subject As String
Dim title As String
' get and display standard properties
author = ActiveDocument.SummaryInfo.author
comments = ActiveDocument.SummaryInfo.comments
hyperLink = ActiveDocument.SummaryInfo.HyperlinkBase
keyWord = ActiveDocument.SummaryInfo.Keywords
lastSave = ActiveDocument.SummaryInfo.LastSavedBy
revision = ActiveDocument.SummaryInfo.RevisionNumber
subject = ActiveDocument.SummaryInfo.subject
title = ActiveDocument.SummaryInfo.title
MsgBox "The standard drawing properties are " & vbCrLf & _
"Title = " & title & vbCrLf & _
"RevisionNumber = " & revision & vbCrLf & _
"Subject = " & subject & vbCrLf & _
"Author = " & author & vbCrLf & _
"Comments = " & comments & vbCrLf & _
"HyperlinkBase = " & hyperLink & vbCrLf & _
"Keywords = " & keyWord & vbCrLf & _
"LastSavedBy = " & lastSave & vbCrLf
